keropi
Hiya!
I recently got a 10mhz XT clone, a HYUNDAI "Pony" that is based on the SUPER-16TE motherboard:
I began restoring it and cleaning up after battery acid... some parts like the DB25 ports and a couple of sockets need replacing but other than that the machine works.
Now this machine boots at 10mhz , the classic ctrl+atl+minus/plus "speed shortcut" does not work with it, anyone knows if this board supports 4,77mhz speed? There is no turbo button and all I could find in terms of settings are the configuration jumper ones here: https://th99.bl4ckb0x.de/m/E-H/30644.htm
I can also post a dump of the BIOS if that helps.Any info/tips on the matter will be greatly appreciated!
Thanks in advance
Thanks in advance
