bvcderrttyyhjjjk
Hello,
came back for help again, you guys always save me when I think I'm screwed.
So, long story short, I bought an Async Communication Card for my IBM 5155, because it didn't have a serial port and I wanted one to do some experimenting.
I was about to install it, did some reading and figured I needed to reverse the "shunt block" at the top right of the card to make it the primary serial adapter.
This thing basically goes into an 8 pin IC socket but seems to be just jumpering two of the four pins across.
I go to pull it out and one of the pins snaps right off. Maybe I should have been gentler, maybe the previous owner damaged it already, maybe both.
Anyway, I now need a replacement, but almost an hour of googling has not produced anything useful. I can't find a part like that anywhere.
I just wanted to check if anyone here ever dealt with this issue or knows where to find a component like that.
Thank you!
Thank you!
