That is correctBut it works in Windows? Is it an IDE (ATAPI) CD-Rom?
So to clarify, in your config sys you have:
Code:DEVICEHIGH=C:\Drivers\jload.exe C:\Drivers\XCDROM32.DLL /D:CD
and in the autoexec.bat it is:
Code:LH C:\Drivers\SHSUCDX.EXE /C /D:CD /L:D
Yep, the cdrom works just fine in Windows. What has been loaded in DOS can be seen on the screen. The thing I see that is wrong isThat should work just fine with an IDE (atapi) cd-rom. Can you post the exact error (word of word) and any error numbers that it gives you?
"SHSUCDX Installed.
Drives Assigned
Drive Driver Unit
D: CD 0
Label not found"
When I attempt to access a file in the D drive it gives the error
"Bad command or file name"
" Volume in drive D has no label
Not ready"
