Creideiki
Hello again everyone. I've not been very talkative of late, but I have been lurking for a while. (Though, that too has been a bit interrupted by my coursework.)
I've recently, come across a nice RSTS/E v9.6 distribution. This page to be specific. And I've been having quite some fun with it.
Now, the major questions I have are:
If you're wondering I don't actually have a real 11/70, as I don't have the room for one, nor have I found any with easy acquisition distance, so I'm running everything off of SIMH for now.
And speaking of SIMH, I'm trying to figure out how I can turn the tapefiles from here into a functional/bootable UNIX V7M install tape (both as an image for SIMH, and for the purposes of giving to a good friend of mine who also can't figure out how to get it working (with his real PDP-11/83... lucky sob).
Also, yeah, sorry for the extremely long post. And I'm not to sure this is in the correct forum, but this is DEC related.
- How would one add one (or more) "permanent" disks to the system? My current distribution is mimicking a system I once had the pleasure of using (that is, the system is an 11/70 (4M only because I don't remember the actual memory size of the original), with two RM80s as the "permanent" system disks, and an RL01 as a "removable" storage disk, there was also a TE16 magtape), and I'm trying to figure out how to "spread" RSTS from being constrained to DR0: to spanning DR0: and DR1: at the once. (DL0: is more or less for use by individual users, so there's no reason to need to automount it at system start up).
- I was only an RSTS/E user, not an administrator, but how does one add (non-privileged) users to the system? I know you need to use
create/account [disk]:[ppn]
Code:create/accound [disk]:[ppn]/PRIVILEGES=NONE
- Another question of the noob RSTS/E administrator, whom, what or where do I have to modify to change the banner from "RSTS is on the air..." to something more customized? Furthermore - although I know it was an undocumented feature - from v9.0 upwards there was the feature (read: easter egg) to display the date as a stardate (you know, from Star Trek), how did one enable that again? (I cannot for the life of me remember how.)
- Also finally, does any one know where I can find earlier versions of RSTS/E? (Other then the V7 that's floating around.) And conversely, does any one know where to find the later versions of RSTS/E? I know for a fact that Mentec seems to have dropped off the face of the Earth, so I can't ask them anything.
