blackepyon
And yeah, this set is under the 100mm square mark.
I've FINALLY finalized my PLUS version of the XT-IDE rev.4, and have submitted that to PCBWay for review. Revision 1, anyways, fingers crossed everything works, because I had to relay and re-route everything from the original to make it all fit the way I wanted. 140mm x 98mm, plus a 18mm x129mm back-plane soldered on at a right angle (gonna use 6-32 PEM nuts to secure it to the chassis).
I'd use a metal back-plane instead of PCB, but metal brackets are friggin expensive to get custom made at low volume. The board would be smaller if I didn't have to worry about that guttter, and far smaller than that if I went SMD (but where's the fun in that), but I used the extra space to put in that rear-facing IDE header I wanted.
If it all works, I'll put it up on Git-Hub. The soldered-on back-plane will be a handy template for future PLUS cards, if I didn't botch up my measurements. Fingers crossed.
