Adventurer
Sometimes, when you want to do something new, you have to make mistakes. This was exactly the case with IBM, developing portable laptop in the middle of 80-ties. In some ways, it was revolutionary - dual 3,5 inch floppies, with 720K storage offered about more storage than 5,25 inch floppy discs, ability to work without grid power, instant on/off, thanks to CMOS based CPU, which was backed up by rechargeable main Ni-CD battery.
However, it had serious flaws as well. First, it was expensive for a portable - just base unit would cost about 2,000 USD. It would not be a problem, since the price seems to be fair, comparing to other computers from the same time, however, IBM 5140 was missing any expansion ports. Need COM port and LPT? No problem, just buy add on extension for about 200 USD. Need to connect an external monitor? Again, buy another addon, whicn just sticks to the current one. Given the fact, that COM ports were used more than often at that time, and having rather poor non-backlit LCD, which could be read in only very bright light, an external monitor was needed when used on a desk. As a result, usable configuration would cost much more than expected, and you would need a very long table, if you would want to connect all accesories at the back of this PC, making it even more heavy.
The heart of the unit runs at whooping 4,77 Mhz, and base RAM was 256, could be expanded to maximum 640K.
After suffering poor sales and dealing with unsatisfied customers, IBM released an updated model of 5140, solving one major problem - display now had a nice blue backlight, and was much better. Other than that, everything remained the same, and this update did not make a significant boost to it's sales, and it was finally discontinued a few years later.
Still, the unit was very well made (all metal body), and the mechanical keyboard with brown Alps switches is one of the best I've ever used:
This took me a long time to find blue backlit model in near mint state. Even Ni-CD battery is accepting charge, and it can run on it as well. Despite cleaning, drive A: often gets read errors when restarting, but this is the only flaw I have found so far. The display is great for indoor use as well, but pretty useless outdoors. Maybe will use it in November for NaNoWriMo
