IBM 5155 keyboard cable... very oily
spaghetticode
Italy
Hi, the keyboard cable of my 5155 portable computer keeps exudating some oily substance.
I wonder if there's any cure for it, if it's a known issue, and if I should start looking for (or building) a replacement. As far as now it works properly, but there's no way I can touch the cable and avoid washing my hands, it's rather annoying.
I have other IBM keyboards, model F from PCs and XTs, and I never noticed any issue with them.
The jacket is de-polymerizing. About the best you can do is wipe it down with IPA to remove the oil and cross your fingers that the jacket doesn't completely deteriorate.
This might sound really bizarre, but when cleaning cords, I've had good luck with WD40! I tried it on a hunch and it works great, especially on the "rubbery" cords. It's also great for removing sticker residue or any other type of "Goo". Maybe try it on a short inconspicuous section of the cord and see if that helps?
Regardless of whatever solvent you use on the effervescing plasticizer, the vinyl jacket is breaking down and will eventually start disintegrating. I imagine that mineral spirits will work just as well.
I have 3 IBM Type F keyboards in my "to do" pile. One of the keyboards has a very sticky coiled cable. The other two are fine, so far. AFAIK, they have all been kept/stored in similar conditions. Given my experience with the infamous "green goo" problem known to anyone who ever worked in a #1ESS/#1AESS environment, the deterioration of these polymers is likely confined to certain production batches and/or plants. Further, once the polymer starts deteriorating, the process continues until it all turns to goo.
I brushed and scrubbed mine with a mix of baking soda and soap, rinsing and repeating a few times. Now it feels very smooth and clean while looking like new. I don't know if it was external oily grime or the cable rotting that made it so disgusting though.
