IBM 62X0776 switches
SunDown79
Netherlands
Does anyone know what the 4 switches are for on a 62X0776 MFM controller card ?
I had a look through my IBM hardware book but it isn't in there :(
Did find a similar card where the switches just select what kind of harddisks are connected to the card.
Xebec/IBM 62X0776
Xebec/IBM 62X0776
Switches 1 & 2 configure drive 0 (C:)
Switches 3 & 4 configure drive 1 (D:)
0 0 = Type 13 (e.g. WD25)
0 1 = Type 2 (e.g. ST-225)
1 0 = Type 16
1 1 = Type 1 (e.g. ST-412)
Source: Upgrading & Repairing PC's (Mueller), 5th Edition, page 763
Thanks, so its the same as in my service manual.
Was hoping it would contain some magic function but it doesn't ;)
Am looking to get a MFM controller into a Commodore PC20-III (which already has an onboard XT-IDE interface which probably doesn't like the MFM card).
Please help me! I'm have IBM XT too, My HDD can't starting on IBM XT. Fdisk says "error reading fixed disk" :(
But other computer (386) format this drive on 10 mb. very good (as type "1" on bios) Also i was transfer system on that drive and 386 boot from that HDD good. What the problem?
HDD and wires are good, means the controller?
Remember first time he found that HDD as HDD on 20 megabutes, but only 10 present on ST-412 HDD, and i could format only 50% HDD :) But now controller don't want to work with HDD :(
I found "modem7" jumper settings, but they can't help me? and what is:
( 1 0 = Type 16 ) that meens no HDD ?
The controller in the 386 and the controller in the XT are probably using a different low-level format.
Have you tried to perform a low-level format of the HDD when it is in the XT?
Step 1: low-level format
Step 2: FDISK
Step 3: FORMAT
Is the drive an ST-412 (you do not actually say so).
What is the HDD controller in your IBM XT? A photo is good. Is it the same as eBay item 140309982308?
XTs can be fitted with different makes and models of HDD controllers. Those switch settings are for a particular make/model of controller - the IBM/Xebec controller that has switches.
0 = off
1 = on
And so if you have that controller, and you have an ST-412, set switches 1 and 2 on the controller to 'on'.
maybe, but i don't tried low-level format on XT, how i can start it?
debug.com
g=c800:5
Yes, HDD is ST-412/ And yes, controller it the same as eBay item 140309982308
ok, but another two? 3 an 4, turn it off ?
Good. The drive and controller are probably the ones fitted to the computer by IBM.
3 and 4 only need to be set if you have a second drive on the cable.
debug.com
g=c800:5
The g=c800:x method does not work on this controller.
You'll need the Advanced Diagnostics Disk for the IBM XT, or a third-party hard drive utility such as SpeedStor.
I use SpeedStor myself on my IBM XT which has the same IBM/Xebec controller and ST-412 as you have.
SpeedStor 6.03 is available from http://members.dodo.com.au/~slappanel555/software.htm
On running SpeedStor, choose 'ManualSetup', specify Seagate ST-412, then 'Initialize' then 'StandardInit'.
A few things to check for your single drive installation:
1. On the controller, the data cable plugs into J2, not J3.
2. There is no 'cross-over' (twist) in the control cable to the drive (the wider of the two cables).
2. On the ST-412, there needs to be terminator marked "T-RES" (as shown below)
3. The shunt block should be as shown below.
