Yes, HDD is ST-412/ And yes, controller it the same as eBay item 140309982308
Good. The drive and controller are probably the ones fitted to the computer by IBM.
ok, but another two? 3 an 4, turn it off ?
3 and 4 only need to be set if you have a second drive on the cable.
maybe, but i don't tried low-level format on XT, how i can start it?
debug.com
g=c800:5
The g=c800:x method does not work on this controller.
You'll need the Advanced Diagnostics Disk for the IBM XT, or a third-party hard drive utility such as SpeedStor.
I use SpeedStor myself on my IBM XT which has the same IBM/Xebec controller and ST-412 as you have.
SpeedStor 6.03 is available from
http://members.dodo.com.au/~slappanel555/software.htm
On running SpeedStor, choose 'ManualSetup', specify Seagate ST-412, then 'Initialize' then 'StandardInit'.
A few things to check for your single drive installation:
1. On the controller, the data cable plugs into J2, not J3.
2. There is no 'cross-over' (twist) in the control cable to the drive (the wider of the two cables).
2. On the ST-412, there needs to be terminator marked "T-RES" (as shown below)
3. The shunt block should be as shown below.
