modem7
10k Member
It turns out that I was looking at a photo of an INTEL ABOVE BOARD AT (it has "ABOVE BOARD AT" printed on it). I subsequently found a photo that exactly matches with what you have. That photo is simply described as "Intel above board", and so I do not know whether you have the original Intel Above Board, or some variation of it. Maybe someone reading this who knows will comment.I only see Intel on the memory board. No other writing. I will upload here.
Sounds convincing. I am unfamiliar with the card. You may need to run the software that was supplied with the card in order to see the RAM configuration. Maybe someone reading this who knows will comment.I suspect it's an inboard Intel 386 card because of the sticker on the case, and the card here.
