offensive_Jerk
I don't like having that 386 card in the machine. It takes up a slot, and it's a pain to remove since it plugs in the CPU socket. I want to just keep it a 286 machine.
I guess the question is, does mikey99 have knowledge about this specific card, or was he making a comment based on what he has seen some other cards do?So according to mikey99, the intel driver needs to load for the rest of the ram to be available.
Looks like 1.25MB RAM on the card.
After closer inspection it appears to have six banks of 256K chips plus two banks of 64K chips which would be 1.625 MB.
I think the Above board I have is the same except it has a serial/parallel port and holds only 1.5MB.
I tried the Above board in my PC/AT yesterday, but found that the card had a short on the -12V line
preventing the PC from even powering on.....argh. While looking at the card last night I found a shorted
tantalum capacitor on the card which I removed..... I'll try this again later today. My card only has two
banks of 256K chips installed. I need to determine how to set the switches first.
He's probably referring to ABISA not detecting it.. He's testing the card that I bought from him (it's going in a Tandy 1000SX). He's going to try the on that I was looking at that implicitly mentions the PS/286 / Plus / Plus I/O, etc.. Apparently if you put in the shunt, when it's in 16bit mode, the machine won't even boot.. Weird.
It's got nothing to do with switches on the card. Machine compatibility is in its BIOS. If the BIOS has something in it that the program (setupat) is not expecting then it might generate that message. Does your AT have the original IBM BIOS? It might have been replaced or might even be corrupt.But now when I run the SETUPAT.EXE it says that your computer is not completely compatible with the IBM AT. Funny, since it IS an IBM AT. Maybe the switches are out of wack or something.
