robbo007
Hi guys,
Has anyone setup the IBM ISA 16 BIT 16/4 Token Ring Adapter under MSDOS? I'm trying to use the IBM local area network support program 1.1 (DXMA0MOD.SYS and DXMC0MOD.SYS in my config.sys) which I used with my 8bit ISA Token Ring network adapter but its not detecting the card. Do I need to use another .sys file for this card? I've tried changing jumpers using this: http://ps-2.kev009.com/eprmhtml/eprm0/f2048.htm but no luck. Its either the card is broken or I'm using the wrong driver to load it in MSDOS.
Thanks,
Thanks,
