IBM luggable P70 - help with broken screen hinge and a couple other Q's
I won't be uploading it to Thingiverse at this time (I have a side hobby business selling prints of the designs I create), but I am happy to provide the file to anyone who wants it for personal use.
This is fantastic! I'm in the UK and wondering whether you'd still be willing to send the CAD file so I can print for my personal P70 which has two broken hinges? Thank you.
I need to find an extra spring as one was missing when I bought the P70.
Also, look at that, nearly a year since your post. What a coincidence!
How was the hinge you 3D printed been holding up?
Thanks!
hi i'm new to this ibm, it works fine, but you need to replace the hinges and floppy drive. I live in Spain and here it is impossible to get parts, I have manufactured the cable to adapt a gotek, but it does not work, it tries to read the track and then it stops. If someone has any experience to help me please, I will continue to share my progress. I apologize for the translation that I have done with google teanslator
Any chance you would be able to send me a copy of the files? I've recently picked up a P70 (of course with broken hinges) and would very much like to print new ones in CFRP. Thanks!
It printed well, though I made a few tweaks to it to eliminate the need for the majority of the part to have supports. I also tweaked it to make one of the two hinges a hair thicker since there is room for it. The original part has a few cutouts reduce weight and these aren't needed with a 3D printed part since it's possible to make the inside hollow. Not that weight is terribly important here; no one is carrying one of these around the airport! That said, the 3D printed part weighs less.
Hi markgm,
I have two P70s both with a broken right hinge and I'd appreciate getting access to the files so I can print them on my own printer, if you're still doing that. :) Shipping to my location alone via eBay is 24$ so that's not a great option, but I value your effort in creating the models, so I'd be happy to pay for the STLs alone.
As for non-working floppy drives: In all P70s I recently got (I set out to buy one, and came home with three...) the drives were non-functional. The motor was spinning but it was audibly running too fast, and the computer would hang for a long time if a disk was inserted on boot. Slowing the motor down with a finger to get closer to the expected speed would result in some audible head seeks, but it was too unreliable to get any really good reads and the computer continued as if it didn't find a boot disk.
In all three drives, I found the same two capacitors that had leaked terribly, a 4.7uF and 10uF (IIRC) one. Replacing them (and ripping the solder pads off in one case due to the advanced state of corrosion) restored function on all three drives.
I've marked them in this picture (the only one I took), note that the 10uF one is already removed in it: floppy_caps.jpg
I hope that information might help someone in the future!
Cheers
mikerofone
I've had the same issues with those drives, the leaking capacitors do a fair bit of damage. Replacing all of the caps brought the drive back to life for me as well. While you have the drive out you might as well replace all of the others, as they will inevitably leak!
Thanks to markgm generously sharing his designs, I was able to get my two P70s fixed. :)
I printed the hinges on my Prusa MK3S+ using Prusament PLA, and they seem very very sturdy. For those doing this at home: Infill doesn't matter, as the main stress as far as I can tell is at the top of the hinges, where the walls are so thin that they're solid either way. The model only required little supports. For reference, this is the face I lay the piece on (looking at the bottom side), and where I added supports (blue surfaces):
Getting the old hinges disassembled is a pain, as it requires removing the old metal nuts IBM used. I didn't have the tools to drill them out, but managed to eat enough of them away with a dremel cutting disc that they could be pulled out with some force. This was not a museum-quality restoration, as this was the first time that I ever used a dremel... but it worked!
For the center axle, I happened to have some leftover IKEA screws lying around that had a good diameter thread, just thick enough to eat into the plastic a bit, and nice, nearly flush heads. The heads didn't have any slits for a screwdriver, so I screwed them in with pliers (see the bite marks?).
The top nut I replaced with M3x16 screws and M3 washers. M3x10 would likely have worked too, and looked a bit neater, but longer than 16 would cause problems.
One of the machines also had the retaining latch of the right display hinge snap in half, so the screen would no longer stay closed. Luckily, that was a simple enough part that I could quickly throw together a replacement in TinkerCAD, which I've also shared on Printables.
And with that, the screen is back to its full former glory!
Video proof: https://photos.app.goo.gl/cjndrBFtffDmpDRV9
And if you want to see even more pictures, you can see all of them in this album: https://photos.app.goo.gl/fip5FddQ2zu4jv9g6
In one of the machines, the display doesn't actually stay fully extended, but slowly slides back to about 40% level. In that one, I only fixed the right hinge as the left one was still intact, and I managed to bend the right metal part a bit. It was the one I worked on first, I became more careful on the other ones. :)
Again: Thanks a lot for your help and for sharing the hinge files, markgm! I don't think I'd have had the nerves to start making my own models and taking a dremel to the machine if I hadn't had your work to start on. :) And it turned out to be a fun and rewarding journey!
For future reference, these are the links to the display latch thingy I made: TinkerCAD (raw model), Printables (for 3D printing yourself)
Cheers
mikerofone
Hi @markgm ! I have 4 IBM P70's and one P75 at home and I plan to sell 3 of the P70. Before that, I want to replace the hinges (also need to replace the caps), as well as in the other 2 that I want to keep for myself. I have a 3d printer, but I have little experience in drawing models myself, so I would kindly ask you if you are willing to share the models? I have no intention to use these for "commercial" interests, just for the models that are (currently) mine. I would really appreciate your help!
Best wishes for 2023!
Markus
Thank goodness I found this thread, I was just about to start modelling replacement hinges myself! I have a Japanese IBM PS/55 Type 5545-T06 that I'm currently in the process of repairing for my collection. Despite IBM Japan's insistence on making their machines different enough to their western counterparts to be annoying, thankfully the hinges appear to be the same as on the P70.
Would you be able to send me those files please so I can 3D print them myself? I'm going to print them in PETG first, and then ABS if the quality isn't up to snuff.
Cheers!
Jordan
I just bought a P70 yesterday and it has broken hinges as I was suspecting after reading up on them.
@markgm can I please get a copy of the 3D print files for non-commercial use. Thanks
I know this is an older thread but do you still have the file? Thanks
I figured I'd bump an old thread instead of creating a new one as I had the same issue happen with mine. This would be infinitely easier to fix if IBM hadn't thought rivets were the best way to assemble this computer! I'm not sure if anyone created a new plastic part yet, but I'm about 80% there, assuming it prints well.View attachment 1037483
Super old thread, but anyone care to share this file? Both of my hinges are toast.
Tried to follow all links in similar threads, but's a dead end.
Hey! Did you ever track down the 3D file in the end? I’m in the same boat and would love to skip the reverse-engineering adventure if it already exists
Hello @markgm, I’m in the process of restoring my p70 and a very good friend of mine has dismantled the screen and found out the hinges were broken. He would be able to print it with his 3d printer, would you agree to send me the file ?
I would greatly appreciate it 😊
