Chuck(G)
25k Member
i think i might need to clean the floppy drives in my ibm at because they leave some dust on my disks when i take them out and sometimes i have to blow inside of the drive to get the floppies to read, could someone maybe send me a link to a tutorial about cleaning an ibm at's floppy drives? thanks.
Yes, the power supply fan keeps the case at a negative pressure with respect to the outside, which means that dust gets sucked in through the floppy slots.
I'd first try the minimum--just blow the dust out of everything with some low-pressure compressed air. As long as the dust hasn't caked onto the heads you should be okay. Otherwise, you'll want to moisten a cotton swab (Q-tip) in some denatured alcohol and gently wipe the space between the upper and lower heads. Or you can use a cleaning disk for your drive, but those are pretty scarce nowadays.
