RetroMagic
- Joined
- Oct 6, 2024
- Messages
- 12
Hi! I recently got an IBM PC Server 330. However, I can’t get it to boot, and I don’t even know where to start. Here’s what I know.
- The hard drive bays (four IBM Ultrastar drives are currently installed) have a green light on for each but none of the drives spin up - the amber activity lights never come on either
- I set the system jumpers from tamper protection to CMOS clear to see if that changed anything - the rest match the diagram on the inner side of the case panel
- I replaced the CMOS battery to see if that changed anything
- The keyboard blinks the num/scroll/caps lock lights on power up
- The fans all run
- No beeps from the system speaker
- Processor gets warm (not bad just enough to know it's doing something)
- Reseated the RAM and voltage regular module on the daughter board at the bottom of the main board
- Don’t see any internal damage or leaking
- Ethernet Enable LED on the system board is on - the three RAID lights are off
- No video is outputted
- Other drives like the CD drive and Zip drive power on
- Below are the system indicators and the descriptions from the manual
