Lorne
Did you do a low-level format?
Since you don't know where the ST-225 came from or what controller it was last used with, you do need to do a low-level format before an FDISK/FORMAT. You have to establish the basic physical format before you read and write to it.
SpeedStor software will perform a low-level format with Xebec and Xebec-made-for-IBM controllers.I've looked on the web, in this forum, and in my DOS & GTO manuals, and I can't find stuff about how to do a low level format. Where is this info? Hiding?
I've found stuff that says I can do a LLF from Debug using g=C800:5 and another saying g=C800:3.
I've tried both, and they both just hang.
I read something else that said: "The earliest HDD controllers for the IBM PC (the Xebec) did not have a LL format routine in the cards BIOS, the LL format was on the Advanced Diagnostics Disk! Typing the g=C800:5 command without the disk would just hang the computer, forcing a reset."
