I thought I might just as well document this here, as the information might be useful for someone stuck in a similar situation.
Disclaimer: I know next to nothing about OpenVMS. My skills are pretty much limited to basic dabbling.
My scenario: a MicroVAX 3100-30 with one hard disk, no CD-ROM or tape drive. Also, no other systems with SCSI adapters easily available. I wanted to install OpenVMS 7.3.
First I installed simh on my laptop, giving it access to the Ethernet port on the laptop. Then, I installed OpenVMS 7.3 on that, which was rather straightforward. I used hostname VVAX, which will appear later in this instruction. After installation, I ran @CLUSTER_CONFIG and added the MicroVAX as a node in my new cluster. When giving machines addresses, one must adhere to this rule:
SCSSYSTEMID = (DECnet area *1024) + node number; thus, DECnet address 1.1 = SCSSYSTEMID 1025.
Then I connected the machines together with an Ethernet cable and told the MicroVAX to boot off the network and it Just Worked on first try, generated itself a new system image, rebooted and rejoined the cluster. To share the installation media, on the simh VVAX I did:
A short walk to the MicroVAX console, logged in as SYSTEM (same password as on VVAX) and ran this:
The CD contents were displayed. Yay!
Next I mounted the MicroVAX local disk as "foreign" - I think this means that the disk device can be accessed, but accessing the filesystem is not attempted. The HDD device name on my system is DKA300. I restored the VMS073.B save set and did a cool trick someone suggested on Usenet a long time ago - copied the other installation savesets to the local disk so that they can be found directly from there. This allows you to use the same drive as both installation source media and destination. Commands executed were:
At the chevron prompt I issued B DKA300 and was instantly greeted by the OpenVMS 7.3 installer. I told the installer to use DKA300: as installation source when prompted, and everything just worked. After installation I ran the license PAK file and installed the TCP/IP protocol suite.
A bonus picture of the system running AUTOGEN:
I know, I really should clean up the VT220.
MOUNT /CLUSTER DUA2 VAXVMS073
DIR VVAX$DUA2:[000000]
MOUNT /FOREIGN DKA300:
BACKUP VMS073.B/SAVE_SET DKA300:/IMAGE
$! let's mount it again so that we can actually read the filesystem
DISMOUNT DKA300:
MOUNT /OV=ID DKA300:
$! copy stuff as described
COPY VVAX$DUA2:[000000]VMS073.* DKA300:[000000]
$! you could copy the DECnet stuff as well now, if you want - I just copied TCP/IP
COPY VVAX$DUA2:[TCPIP_VAX051.KIT]*.* DKA300:[000000]
$! finish and reboot from local hard disk
DISMOUNT DKA300:
SHUTDOWN
