Some good info on the board here: http://www.frankshospitalworkshop.c...manuals/Coulter_STKS_DMS_-_Service_manual.pdf
Starting at PDF page 20
Thanks, however this is for the 301z. I have added the manual to my site.Some good info on the board here: http://www.frankshospitalworkshop.c...manuals/Coulter_STKS_DMS_-_Service_manual.pdf
Thank you. I've been looking for that Micronics 20MHz board for a while. It has a 10MHz AT bus, and was curious how this non-cached 20/10MHz system compares to a 20/8MHz cached system. The intel 302 board is also an interesting one. The memory card bus is different to the 301/301z. It is tacked on to a 16bit slot, instead of an 8bit slot. The manual calls this an AT-32 bus. There is at-least one HDD controller that fits into this. A little known bus that was lost when EISA took over in '89._mR_Slug might find the digging I've been doing on Syscon Consulting and similar motherboard designs under
