per
The reason I post this here, is becuase of the fact that the Tiki-100 run a CP/M clone called KP/M (later known as "Tiko"). KP/M is entirely written in Z80 Assembly in Norway and completely independent of CP/M, however, KP/M it is said to be 100% CP/M 2.2 compatible.
Anyways, I just got my Tiki-100, and I have now tested it. What I can conclude with is that the machine works, but the RF-modulator is problably broken (the composite out connector is missing, but it gives a valid signal at least). I will consider to make a 6-pin DIN to SCART adapter for it, because then I get better quality graphics, or solder in a new composite connector.
It contains an analog/digital interface card, which is that extra connector you see in the pictures provided by QuantumII (above the serial/parallel ports).
Anyways, here are some pictures.
