I think you mean DVI. DisplayPort is a constant clock fully packetized protocol. Very different but open.
DVI and HDMI share the same protocol lineage.
I guess I can see using DVI (vs displayport) since many folks have one of those adapters, but my opinion really is that it's just worth it to pay the HDMI license fee and add the cost
Is there any chip that can take parallel binary RGB plus the sync signals and deliver a DVI output?
Agreed on this. Though, if someone could make an inexpensive (sub $60) MFM-IDE (or MFM/RLL to anything current really) I'd be all in on that since the XT-IDE doesn't help with non PC's. While they exist, they're all about $200+. Of course, this isn't an ISA solution as the OP requested, so it won't help.
That's something I intend to work on, if no one gets to it before me. I've got a bunch of non-PC systems that would benefit from it.
I've also considered doing a new 8-bit ISA network card, but existing Ethernet cards that will work with 8-bit ISA are so cheap and available that it's not worth running the bare boards. I can't speak to the attractiveness of 8-bit ISA WiFi since I personally hardwire everything possible. In any event, you'd have to also provide packet drivers. That's the beauty of some of the RS-232 and parallel port WiFi bridge devices, they'll just use a SLIP or PPP driver, and they have the added bonus of working on laptops and portables too..
As far as tandy graphics go, since I plan to use an FPGA, I should technically be able to emulate any video card you want. However, I'm not sure how Tandy graphics work, or if they are even compatible with the ISA bus. I'm not really educated in that area.
deathshadow said:Intelligent MPU-401 compatible that does NOT require the external breakout box. Sure the box is "easier" to come by, but why can't we just have an all in one replacement card as "new stock' -- or better as a kit? Is it really so hard to fit a pair (or trio) of 5 pin DIN sockets into a expansion slot?
deathshadow said:High density floppy controller. Whist sure they exist they are getting harder to find. Something on par with the XT-IDE -- maybe even share the ROM space / extend the card functionality?
deathshadow said:PS/2 port -- a proper PS/2 mouse interface for older PC/XT/AT class machines is something I've not seen. Be more useful than dicking around with USB.
Yup, the mfm/rll replacement would be the highest interest for me since there are no "average consumer" alternatives for that... I think the DREM is really focused on the business market (at business prices).
I'm not sure that I follow--do you mean something like David Gesswein's board? Seems affordable enough.
$175 seemed high to me. My SCSI2SD was a little over $70 after shipping. Beyond that, it wasn't really clear on if one could just swap out a RLL drive in something like an Atari ST Megafile and it would just work (with basic settings). But yeah, at those prices ($175 or $250 for the DREM), I'd rather just dump the drive enclosure completely and go for one of the $125 or so CF adapters. Just would like to see something competitive in the price range of the SCSI2SD that was as refined as well. Something that would let me use everything as it originally worked.
Indeed, I could use a few of such cards, the best would be probably a clone of Orchid Ramquest 8/16 - up to 32MB of RAM, extended or expanded, with support for both 8- and 16-bit ISA.286/AT memory card -- whilst we have EMS boards and conventional memory boards, finding working RampageAT and its ilk is getting more and more difficult. Particularly given how will DIP RAM chips are aging.
There's a guy who published artwork for doing a job similar to a Kyroflux using a RPi. Of course, if there were a real market for one, the Chinese would turn them out for $25 shipped.
10 years ago, the notion of a full-LM.
HDMI is actually on its way out, thankfully.
Sergey's ISA Floppy Disk and Serial Controller
Also I would argue they aren't that hard to find. Just about any 16-bit Multi-I/O card will have an HD floppy controller and they are regularly on ebay for about $20.
Which nobody seems to sell even just bare boards for, and seems a bit too complicated for its own good... and again why not just put the two to three DIN on the back instead of a breakout cable?
Last thing I need is another serial port, but good to know the project exists. Shame again, nobody seems to make the boards or provide kits.
Which does jack good in a 8 bit slot particularly when most 16 bit cards don't provide the ROM -- they rely on the AT class ROM to provide that functionality. The few 8 bit controllers available out there from old stock are going for $150 a pop or more for something that should probably be a $35 kit, $70 or less assembled.Also I would argue they aren't that hard to find. Just about any 16-bit Multi-I/O card will have an HD floppy controller and they are regularly on ebay for about $20.
So give it a different IRQ and alter the drivers. That shouldn't be rocket science.A "proper" PS/2 interface requires IRQ 12, but PS/2 to serial converters exist.
