tingo
I notoice that the output of 'hinv -v' (from Irix) is the same as just 'hinv'. Is that normal?
here is the other one:
I thought the '-v' parameter was supposed to show me more stuff?
$ hinv -v
Iris Audio Processor: version A2 revision 4.1.0
1 100 MHZ IP22 Processor
FPU: MIPS R4000 Floating Point Coprocessor Revision: 0.0
CPU: MIPS R4400 Processor Chip Revision: 5.0
On-board serial ports: 2
On-board bi-directional parallel port
Data cache size: 16 Kbytes
Instruction cache size: 16 Kbytes
Secondary unified instruction/data cache size: 1 Mbyte on Processor 0
Main memory size: 64 Mbytes
Vino video: unit 0, revision 0, IndyCam connected
Integral ISDN: Basic Rate Interface unit 0, revision 1.0
Integral Ethernet: ec0, version 1
Integral SCSI controller 0: Version WD33C93B, revision D
Disk drive: unit 2 on SCSI controller 0
Disk drive: unit 1 on SCSI controller 0
Graphics board: Indy 8-bit
$ hinv
