carlos12
I read the invaluable information at seasip.info. I read on this site that the Plantronics Colorplus has a register to activate the additional plane needed to use its 16 color special mode(port 03DDh). The problem is that this register is write only. I also tried to write and read a value at the second plane adress (0BC000h), but it returns the same value also in regular CGAs.
So, Is there any way to detect a Plantronics Colorplus card by software, distinguishing it from regular CGAs?
Thank you very much for your help.
