Chuck(G)
25k Member
Did the loopback test involve any special plugs/jumpers? If not, then you probably need to look and see if you've select the RS422 or RS232 I/O when you meant to select the opposite.
There's also the handshaking issue, i.e. how the printer signals the computer that it is a) plugged in and turned on and b) that it is ready to receive a character; unfortunately this is not as 'standard' as the parallel port. Do you get an error message when you try to print?Yes there were jumpers on specific pins on the cables. I followed this guide: http://www.ni.com/white-paper/3450/en/
I also verified the test failed when I removed the jumpers. All ports passed.
But I still can't get the printer to work on any of them. I have it set up on the parallel port and it works fine with that interface. It also works fine as a network printer. But the serial ports do work.
Page 11-7 of the printer's Users Guide indicates that the printer's RS-232 port is of type DTE.the printer (HP Designjet 755cm)
I see. Photo #3 in post #18.one of those pics suggests that the card can output 5v on the serial ports,
If the card is outputing +/- 5 volt levels, then it could be a problem. In my time, I have encountered some RS-232 devices that do not recognise 5 volt levels.i don't know if that means anything or not...
No, a serial mouse does not have a requirement for +/- 5V levels. In fact, the serial ports in the IBM cards supplied with the IBM 5150/5160/5170 output about +/- 10V levels.i guess it really comes down to the device being used and whether or not it has it's own power source. like a serial mouse, which would need the 5 volt, but a serial printer, which wouldn't.
