Kaypro 2x with a Gotek
tradde
Katy, Tx
Are you saying you updated your Gotek with the "debug" version that logs to the USB stick? I have considered doing this myself.
durgadas311
Minnesota
If you can boot off the floppy with the gotek as B, and your boot floppy has PUTSYS.COM, then you should be able to "sysgen" a gotek image in "drive B", and then flip back to the gotek as drive A and boot.
tradde
Katy, Tx
I can and have installed the Gotek as B and booted off A. This is how I know some of the images on it are good as I have run some of the programs. I do not know if my boot floppy has PUTSYS.COM or not. Will have to check. Thanks. So I would need to have a blank images in the Gotek to do this? Or will it create everything? Oh, you mean to have the image I have tried to boot but was not able to boot and it should make it bootable. Got it. I think that is what you mean.
durgadas311
Minnesota
Yes, the "sysgen" process (on most CP/M's, including Kaypro) is independent of files stored on the disk. You could take a WordStar distro disk and "sysgen" it to make it bootable (although that was not recommended in the old days, as one wanted to keep the distro diskettes "pristine").
