shirsch
Sorry Shirsch. I beat you to it. I found the rom here: http://planemo.org/retro/advent-turborom/
I burned it and same result! I am really confused. I think Ineed to pull the board and examine the socket. The original rom works but its only a 24 pin rom. Maybe the last few pins have dry sockets or something. I wish someone who has done with can chime in. I feel as if I am missing something.
Wait, wait, wait... What size is the socket in the motherboard? Are you saying the machine had a 24-pin part in a 28-pin socket? If so, it's certainly possible that the upper address line is not connected - or - possibly the board needs a jumper moved or trace cut. The Advent documentation explains how to add a jumper wire to toggle the top address line appropriately. From your description of the symptoms this is almost certainly the issue.
I put the latest revision of the Kaypro technical manual under the link I sent earlier. Take a very careful stroll through the board layouts and schematic diagrams. There's at least one model with a jumper to choose between 2716 and 2732 on a Kaypro II/4 motherboard. No indication of support for 2764, so you may have to check jumper setting AND do the mod outlined in the TurboROM docs.
