Hello Kaypro Users,
the first prototype for the KayFreHD module had arrived today and works fine at once.
This extended Version of the FreHD module has extra logic and connector for the use in Kaypros.
It get power over the standard Kaypro flat cable. So is no need for an extra power connection.
The first two pictures shows the use in an Kaypro 4/84. The KayFreHD module is direct connected to the J9 header on the mainboard.
The fourth picture shows the use of the KayFreHD in an Kaypro 4/83. There is no I/O connector like in the newer Kaypros.
The "J9" is then on the piggy back board, which is plugged in the Z80 socket. On the board there are bus drivers, some inverters and TTL-logic.
The second 50pin header on the KayFreHD is for the use in the TRS-80. Then you have to remove one LS04 and change the jumper setting.
If there some people who wants this board/board set, i produce a little batch of these boards. Please let me know.
Many thanks to JAQ, without his knowledge, this project wasn't ready until now.
