Hunta
I wanted, as usual, something strange..
The result:
The result:
Testing in progress - Please wait
Memory Size is 256 K Bytes
9 Step memory test
Step 1 2 3 4 5 6 7 8 9
Message 04 Entering Dialog mode
Commands are Help, Boot, List, Setup, Map and Test.
Type a command then press the RETURN key: SETUP
KDJ11-B Setup mode ROM V8.0
Command Description
1 Exit
2 List/change parameters in the Setup table
3 List/change boot translations in the Setup table
4 List/change the automatic boot selections in the Setup table
5 List/change optional user data in the Setup table
6 List/change the switch boot selections in the Setup table
7 List boot programs
8 Initialize the Setup table
9 Save the Setup table into the EEPROM
10 Load EEPROM data into the Setup table
11 Delete an EEPROM boot
12 Load an EEPROM boot into memory
13 Edit/create an EEPROM boot
14 Save boot into the EEPROM
15 Enter ROM ODT
Type a command then press the RETURN key: 1
Exit
Type a command then press the RETURN key: MAP
166.669 MHz
Memory Map
Starting Ending Size in CSR CSR Bus
Address address K Bytes address type type
00000000 - 00777776 256 PMI
Press the RETURN key when ready to continue
I/O page Map
Starting Ending
Address address
17765000 - 17765776 CPU ROM or EEPROM
17770400 - 17770402
17772200 - 17772276 Supervisor I and D PDR/PAR's
17772300 - 17772376 Kernel I and D PDR/PAR's
17772516 MMR3
17773000 - 17773776 CPU ROM
17774400 - 17774416
17776520 - 17776526
17777400 - 17777416
17777520 - 17777524 BCSR, PCR, BCR/BDR
17777534
17777544
17777546 Clock CSR
17777560 - 17777566 Console SLU
17777570
17777572 - 17777576 MMR0,1,2
17777600 - 17777676 User I and D PDR/PAR's
I/O page Map
Starting Ending
Address address
17777744 - 17777752 MSER, CCR, MREG, Hit/Miss
17777766 CPU Error
17777772 PIRQ
17777776 PSW
