mykrowyre
I purchased an Amber monochrome dumb terminal, but it came with a mismatched keyboard. Sold as not working.
I found that the pinout of the keyboard was different than the terminal pinout, so it fried the 7404N buffer chip by sending 12V to the data line.
Upon testing the keyboard with bench supply, I found the clock signal was being sent, but data was not as it that buffer pin was now shorted to ground.
I replaced the buffer chip, and the keyboard is working. But now I have a strange oddity.
The clock signal is now inverted. Instead of the clock pulses being negative (5V to ground), they are now positive.
The data pulses are negative as expected, so that is strange. All of the IBM keyboard protocol examples I can find show negative pulses on clock.
Unfortunately I have no information on the keyboard or the terminal, so I dont know which pins are clock and data on the terminal.
The terminal is a Liberty Aspect 4350. The keyboard only says "ASCII KEYBOARD TAIWAN".
Any input appreciated.
Thanks
Thanks
