I got this keyboard but doesn't work.
Inside there are 74LS05 and 8048AH. 7405 works so would like try replace 8048. I dumped it but content is empty. Is worth to replace or it will not work because dump is required to 8048?
You should get at least 1KB of data back; that may indicate a damaged chip. The 8048AH is pretty quirky when it comes to reading program memory, particularly the mask-programmed versions.
