Kind of 11/73 Console/SLU issue ...
Schroeder
Germany
Did not do that much with my PDP-11s, was more focused on my VAX systems. So, I forgot a lot about addresses and so on.
So, I thought. lets start with a simple setup to relearn...and now I'm stuck.
The backplane is A/B A/B with M3107 next to the CPU.
The front foto shows an SRAM memory card but now it uses the other card. I forget to set it to 18bit address when I took the first photo.
The CPU card does not complain about the DHQ-11 but I get no console. I tried different breakout panels but I just see some dirty characters when power on.
Using QBone to emulate a DL11 i get the @ prompt.
Does the DHQ-11 not support the console?
Btw. does one know how to start the DL11 on the QBone in background?
The console is only supported on a DL interface - not a DH or DV etc.
Ditto for a TU58 / serial bootstrap.
Every system should have a DLV11-J fitted... My suggestion...
Thank you Dave, not the anwser I wanted ... ;)
I've never see the built in hardware ODT console at anything other than 17777560-17777566 or their 16 or 18 bit equivalents.
That said, you don't need a DL/DLV-11 if there is ROM bootstrap code that can start the OS without it. We had many systems w/o a CRT or hardware terminal. But ou need a console serial port if you want to interact with the hardware ODT for debugging or other purposes.
I just set this up myself...
If you go through the demo program, you go through the 'd' option, then 'en DL11' - and that's it...
If you add this to one of the .cmd files then you can enable the DL11 along with something like 'm i' for memory.
In autostart.sh, I reused the memory option (and changed it to option 0):
case $n in
0)
config_info="Just memory"
config_cmd="./memory.sh -aw 22 --leds $n"
memory.sh runs memory.cmd, here's what I changed in memory.cmd
# inputfile for demo to just emulate max memory
# Read in with command line option "demo --cmdfile ..."
d # device menu
pwr # reboot PDP-11
.wait 3000 # wait for PDP-11 to reset
en dl11
m i # install max memory
Correct, and the DHQ11 ist set to that address. The CPU SLU LED is going off with that setting. That is why I hopped it might work with this one.
The DHQ11 is a multiplexed serial line unit. As such, there is a different programming interface to the bus.
Of course, if the machine 'crashes' to ODT, you are now blind...
The machines involved were specialized diagnosic clinical implementations. Support contracts :) (Marquette Electronics, now GE Healthcare) dealt with any failures.
However, we did extract some of the clinical data for research purposes. So I would routinely insert a DLVJ11, connect a CRT and TU58. I halted the machines, then toggled into the TU58 bootstrap for RT-11 to recover the information.
If Schroeder has an OS image that will boot w/o DL's and is configured for DH/DHQ/H/Z-11's it may be possible to skip the "normal" console. This might work on say, an Emulex UC07 or similar.
