Lisa II and SCSI card...
jdreesen
Switzerland
I have here a Lisa II, romset H88, and a SUN remarketing SCSI card. Macworks 1.0.18 is running from an IDEfile disk. However the attached SCSI disk is not seen : am I overlooking something ?
I'd run Macworks plus 2, but do not have the required extra hardware...
Jos
I seem to recall that regular Macworks does not support the SCSI card as it's emulating the 128/512K mac which never had ROM SCSI support. MacWorks Plus emulates a Macintosh Plus on the other hand which shipped with the same SCSI chip.
Yup, the original MacWorks is just the MFS-centric ROM where you have to copy the empty folder and does not even support booting from the HD20. All the 5380 support came with the 512Ke (128K sized) ROMs that are the same as the Mac Plus. If you put one of those "MacSnap" SCSI wedges that sit on just the two ROM sockets on the original 64K ROM set you're going to get the same null results.
