Corey986
Administrator
Ok so I almost have my widget working. I got past my error 82 and also adjusted the “brake” using the correct feeler gauge. I think all that is left is a low level format because it doesn’t boot, I get no errors now just the Lisa caught in a boot loop.
So when I get this thing running 100%, is there any maintenance or preventative steps I should take to keep it running (ie put glue somewhere on the glass for the voice coil to make sure it doesn’t fall off and crack)?
While I generally think I’ll keep my XProfile CF drive as my daily use one, I want to keep the widget working for historical purposes.
Thanks,
Corey
Thanks,
Corey
