Locked EEPROMS, can they be unlocked and re-written?
maferv
Argentina
Hello guys,
I'm going through scrap and occasionally I find EEPROMS, for example an ATMEL AT27C010, MX27C1000, and many more. They look normal, like any other EEPROM. While I can dump the roms without problems, I can't write a single bit into the chips. I assume there's some sort of lock.
Is there a way to unlock them? Is it a hardware limitation?
Cheers.
Oh, I see. Since they come in plastic packaging I thought they were EEPROMS. My bad!
So no chance to repurpose them I guess. I'm reading some people used x-rays.
True EEPROMs can, usually, be erased and rewritten. Also FLASH ROMS can also be erased and rewritten. The difference is EEPROMs can be rewritten on a byte by byte basis. FLASH require a minimum sized block to be erased and written. It varies from the entire chip to a number of smaller blocks.
Larger sized memories are usually FLASH.
Dwight
I managed to erase two chips as if they were regular EEPROMS (AT27C256R and M27C256B). Not all the way through though, they still have some data, and I still can't write into them. I wonder how it was possible since they are OTP EPROMS.
Interestingly in a lot of OTP type devices you can lower bits, with reprogramming but not raise them.
Very interesting, so you can re-use them to some extent. Write in the unprogrammed part and fill the previously programmed area with zeroes.
This guy explains more about it
Many OTP devices were actually just regular EPROMs without the window...
