carlsson said:Yep, it is a perfect fit within 800x600 - which still is used by some 20-30% of the surfers but too many sites (like those I design ;-) neglect. Is that grey material supposed to look like metal or grey wood?
It's supposed to look like a brushed metal. It may be a little dark but I wanted to maintain contrast with the white text.
I am shooting for a site that will fit within 800x600 without horizontal scrolling. In my next iteration (probaby about 2 years out if history is any indication) I am almost certainly going to assume that most folks are semi-current!
carlsson said:While some of us hate it, you might want to consider a top frame or other absolute/fixed positioning of the navigation. With some tweaking, it is possible to use a fixed element without frames (based upon you have some server-side parsing of each page - e.g. written in PHP), but it is optional. You might also want to move the headline inside the navigation?
I'm not a big fan of frames and while I'd like the navigation to be "fixed" I am not willing to sacrifice the rest of my goals for that. That's one reason I have the bottom navigation menu (which needs to be updated to match the top) in case the page was scrolled.
I will probably have to do some code to keep the menu bar on the left growing with the text on the site which might get fun. . .
I pulled the headline from the navigation graphics specifically so that I can have it in straight HTML. I'll be doing some other manipulations like that to make sure that the page is search-optimized. Server side parsing is nice but beyond doing some SSI to get the scripts standardized I probably won't do too much content generation on-the-fly since it really disorients the spiders and makes your rankings plummet.
carlsson said:Regarding the left column is too wide - check it in 800x600 and see if the remaining space is enough for what you want to display. The site I'm currently working with has about exact the same width on its left frame, and wider than that I wouldn't go.
I did come up with the width based on what I need space for in the page area. I'm going to have to resize many of my graphics as is and I don't want them to get too small. I think you're probably right that the size is about where it needs to be.
Thanks tons for the feedback! I'm pretty green at this and I'm learning a lot as I go. . .
Erik
