sqpat
looking for a 5.25" floppy drive i can stick into a newer computer so that i can create a bootdisk or whatever I might need. (These connect just like 3.5" floppy drives right?)
As for DD/HD, as long as I have the 360k diskette, i can write to it with a drive that supports the DS/HD 1.2s right?
No... most that support 3.5" will support 5.25" as well still. The support isn't routinely tested, as most people don't use it, so it may or may not work well, however.Yes they connect like 3,5" ones, but:
- The BIOS of most recent PC's do not support 5.25" floppy drives anymore
Completely true. If you write files to a 360K floppy in a newer drive, or even in a 360K drive on a newer machine, it has a good chance of rendering the disk unreadable in older machines. If you format the disk to 360K (using special switches on the CLI format command), it will DEFINITELY be unreadable.- To make 360K boot floppies, you might need a 360K 5.25" drive. 360K floppies written by HD 1.2 MB 5.25" drives might not be readable in a 360K drive on the vintage machine
While it doesn't distinguish between 360K and 1.2MB, just seeing it as a "5.25 Floppy", it does work, and can write to 360K disks fine. The issue, however, is that the newer hardware borks the disks by using slightly different timings (I'm not sure where or how these come into play). This means that while the disk will continue to be readable on the comp you write it on, and possibly ones with 1.2MB drives, it will not be readable with a vintage 360K comp. I know this firsthand, as I ruined many a 360K boot disk... :/ This could be because XP assumes that it's a 1.2MB floppy.- Windows XP and newer does not support 360K 5.25" drives
The DD 5.25" issue on a 1.2M 5.25" drive has nothing to to with timing. The heart of the PC disk controller is still the NEC uPD765, however buried under silicon it becomes. Timings for double-density media have remained the same since the original IBM 5150 (and before).
The issue at the heart of the matter is the track width. A "360K" drive puts down 48 tracks to the inch; a "1.2M" drive, 96. The way a 1.2M drive handles 360K media is to read or write every other track (0,2,4,6, etc.). This creates a problem when a 360K drive has to read the disk.
The way out of this if you have no 360K drive is to degauss disks before you format and write them in a 1.2M drive.
I use a VHS videotape eraser (audio degaussers generally aren't strong enough) to do this and the disks work fine.
Tape degaussers are pretty simple and Radio Shack sells (still?) a cheap one. You could probably make one because it's just a coil with an optional switch. Check Google images to see fancy ones for studio use. The desk models for 10" reels or 2" tape are expensive but the hand held VHS ones are really simple and can be used for everything - including a 10" pancake. I have one from the thrift shop and it was only a couple of bucks. There is one on eBay right now for forty bucks but you shouldn't have to pay that much. For audio tape recording they used to be essential because you can't otherwise reuse tape unless you are willing to put up with background noise.Aren't degaussers a bit on the expensive side?
