Trixter
No difference. Tried it with "turbo" off and the score was 17. Did the sx20 have a co-pro? It seemed to make a difference in an earlier 286 test results. Also the type of video card affects the score from what I can see. The card in the 386 is not VESA capable.
The video card speed does affect the score, but it shouldn't be so drastic that it makes a 386/33 system perform worse than a 386/20 system. Maybe your board has no secondary cache? I'm not sure. Because your result is so much of an outlier, I'm going to discard it for the time being, and revisit it once I have the full tool done in a few weeks.
Also, the coprocessor has no bearing on the score whatsoever; I wrote the metrics in assembler and did not use any copro instructions. (This was intentional, as one of the core focuses was being able to compare any system with any other, and not all systems have mathcos.)
