Chuck(G)
25k Member
Palantir, Ami Pro, PFS:Write, Multimate Advantage, Peach Text, Volkswriter, XYWrite...
All dead. :sigh:
All dead. :sigh:
I still use it. It works in DOSBox, too.Around here Professional Write was used quite a bit as a DOS word processor (cheap too).
All dead. :sigh:
Ton the other hand Windows and its consistent interface
Really? Really? I can show you three Windows programs that purport to do the same thing and the interfaces will be completely different.
Well drop down menus people can understand (and are somewhat the same between apps) compared to cryptic control+function keys to do things in DOS era programs. The old Classic mac interface was kind of consistent as well until OSX came along.Really? Really? I can show you three Windows programs that purport to do the same thing and the interfaces will be completely different.
The Ctrl-key commands were the main reason why I stuck with WordStar. WordPerfect's function key commands had a much steeper learning curve, and then they threw salt in the wound by changing some of the commands between WP 5.1 and WP 6.0. WordStar's Ctrl-keys were at least partly mnenomic (such as ^PB for Print Bold) and since they used the same letter keys that you used to type, they were quicker to access and had stronger "finger memory" attached to them -- you could touch-type the commands as well as your text!
And isn't it funny that the on-screen help menus of WordStar in "beginner" mode are quite similar to the "Ribbon UI" in recent versions of MS Word?[/img]
The software industry seems to have run low on good new ideas.
vwestlife said:WordPerfect's function key commands had a much steeper learning curve, and then they threw salt in the wound by changing some of the commands between WP 5.1 and WP 6.0.
