chrinFinity
- Joined
- Apr 22, 2011
- Messages
- 6
Hi boys
I am so grateful I found this forum, as so far I've not had much luck getting clear answers.
I recently rescued my childhood Tandy 1000SX from the basement of my dad's house, and I'm working on restoring and upgrading it. I could really use some advice from those more in-the-know than myself.
The unit is a standard SX, it has the 640k upgrade, and it has 2 5.25 inch drives which, so far as I can tell, are 360k's. The machine boots perfectly well on MS-DOS 3.3 (the only boot disk i had handy, sadly), so I know its working. Mind you, since it's DOS 3.3 I'm not sure if those disk drives are really 360k, I seem to recall reading somewhere they might have higher capacity if I try to read them on DOS 3.2, but I have no idea if that's true.
There are a lot of things I wish to do with this machine, and I look forward to sharing the experience with all of you, but first and foremost, I really want to get a 3.5 inch diskette drive installed.
In my posession are a couple of 1.44's, tested working. I've done a lot of reading online and I am getting conflicting information from the documentation I've found. Everyone agrees the original Tandy BIOS and motherboard are not capable of accessing 1.44MB disks. Fair enough. But here is where my information gets murky... Some sources are telling me that the SX won't even recognize the existence of a 1.44 drive, that only 720s will do. Yet, other sources are telling me if I put in 1.44's they'll just behave like 720's. Which is correct?
So far I have tried testing each of the 2 drives individually, with and without twisted cable. I did not bother to try both drives together. Should I?
Please note that in the tests I've run so far, I am powering these 3.5's via an AT power supply I've got plugged-in along side the Tandy, as the SX only has 2 molex and I don't have any adapters to plug in the 4-pin 3.5 floppy power directly to the Tandy. I figured I'd cross that bridge if and when I got it working. I am certain the drive is getting power, because I have accidentally connected the floppy cable backwards once or twice, causing the drive to light up and make noise (oops).
So, my new friends, what will it be? Is there something I've not tried, will I have to shell out for exhorbitantly overpriced 720's, or keep my eyes peeled for an ISA floppy controller with its own BIOS which will run the 1.44's at full capacity?
Ultimately my plan is to get one of those floppy-emulators that run off a USB flash drive - 100 floppy images on one usb stick. I don't want to shell out unless I know it's going to work.
Any advice is deeply appreciated. And this won't be my last question. But you all seem so friendly and knowledgeable, I'm looking forward to this forum.
Sincerely,
Christin
Sincerely,
Christin
