Low Level Disk Format on "IBM"-PCs or are modern PCs capable of reading SD-floppys?
Hello,
thats my first post after I found that forum with it's vast amount of information. There are loads of categories, I hope I found the right one (the <=286 and >=386 PC forums seemed to specific to me) .. else mods should feel free to move my post.
In the 80s my father build a computer system based on the "elektor computer", which is formally a 6502 system. The hardware is finished and quite impressive for a homebrew system, but it lacks of software and documentation .. so I took it into care.
One thing is that I would like to make it capable to write and read FAT12-formatted floppies. Unfortunately, because of the system clock of only 1 MHz, it only supports single density (not enough data rate for double density). Now to my question: Does todays FDCs still support SD and which Lowlevel-Format (Syncheaders, Gaps, Marks .. and so on) and which geometry is used. There IS some standard called ECMA-66 for 5.25" SD Disks, but according to my research even back then nobody really used that standard. I would maybe also add an 3.5" drive, so I would need information for that type of drive, too.
The organisation of the FAT and so one is absolutely clear to me.
If you are interested, I would post some information about this system in exchange for your nice help. You can look at a few pictures till then, if you want to:
https://picasaweb.google.com/106424078464300028239/6809?authkey=Gv1sRgCNmM6cvfx67EhAE
Thanks,
Christian
Hello,
Thanks,
Christian
