IBMMuseum
- Joined
- Aug 28, 2006
- Messages
- 1,488
Maybe this will be better in ¨Rants¨...
Today I´m documenting all of the systems connected on the home network. An XP Pro system in a main room is notably absent in the list of DHCP clients on the router, even though it is on at the time. I check, and sure enough it is set to get the IP address via DHCP.
Next thought is that is an Intel NIC on an Intel brand motherboard, so maybe it has something to do with being a network ¨management¨ adapter. I install a SMC NIC in the PCI slot below it. Everything is identified, and I connect the cable to it instead.
No MAC address or IP shows up on the router...
I go through a few other cards, identifying a couple bad 3Com NICs, but it is the same at every turn with working NICs...
So I am frustrated, this is something to resolve another day. The original Intel NIC is put back in place, putting it in the next slot like the others I tried without success. It is redetected, and labelled as the ¨#2¨ in Device Manager.
And then I see I am out of ¨stealth¨ mode, the IP and MAC address are showing up on the router like they are supposed to...
I want that hour of my life back, upteen system reboots trying everything...
Never seen anything like it...
