cosam
Oh, the pinout can definitely vary. Most of what I've come across are ECB or CBE configurations (or indeed the reverse depending how you look at it). Your Q3 (a BC406) is of the former type. If you screwed it to the bench, pins towards you, the order would be BCE from left to right.I am curious about the power transistor though (see blog). Is the middle leg always regarded as the base and should should resistance between emitter and collector always be infinite when measured across the these pins when out of circuit?
BTW: I don't suppose you have a transitor test setting on your multimeter? I never realised I had one until I looked last night! There's an "hFE" setting on the dial and two rows of four holes for plugging in the transistor.
