I have a Mac SE with an Asante MacCon SE Ethernet board installed. The SE is running 7.1. I installed the drivers for the Ethernet card but it's not communicating. If I run ADLS it identifies the card and MAC address and I can see recieved broadcast packets but none of the other counters show any activity. I've connected it to a 10/100/1000 switch as well as directly connecting it to an older laptop. When it was connected to the switch I tried both manual and DHCP. With the drivers set to DHCP it wouldn't pull an address and I never saw anything in the logs on the DHCP server. The two LEDs on the daughterboard work as expected (one is solid to show the link was detected and the other blinks showing network traffic).
I've verified the cable connecting the Ethernet board and daughterboard is connected correctly.
I'm sure I've overlooked something. Any ideas?
