Usually if there's bad connections around or between the LCD and the controller I would expect to see dead lines but you are getting black lines which look to be evenly spaced. I'd then suspect a problem with the display controller but Mac Portables are a "must-recap" item so unless he's already done that it's hard to say for certain the LCD assembly is faulty.
