If you seek something more reliable (than an original spindle drive) look at a hdd replacement such as BlueSCSI or the like.What's the consensus on keeping HD reliable?
What style button battery holder do you recommend please?
Definitely remove & replace the battery ASAP before it leaks and bombs your motherboard with acid.
Since you brought it up ... *takes out MD degree*There's a good reason why Lithium stopped being used as an anti-psychotic, it had too many nasty side effects.
