The SCELBI 8H preceeded the Mark 8 by a few months. LIke the Mark-8, it supported 4K of SRAM using 1101 spread across 4 boards. It was followed a year later by the 8B which supported 16K of SRAM (2102) and/or EPROM (1702) also spead across 4 boards. The EPROM board could be ordered with MEA programmed into it. MEA was a complete integrated development environment and was used to develop SCELBAL BASIC for the 8008.
Actual power on the 8H is about .6 AMPs on the -9 volt rail, per 1K SRAM board. A 4K system would require about a 3 AMP -9 volt supply. Here is the text from the SCELBI HW manual.
THE BASIC SCELBI CARD SET CONSISTING OF ONE EACH OF: SCELBI #1100 CPU CARD, SCELBI #1101 DBB & OUTPUT CARD, SCELBI #1102 INPUT CARD, AND SCELBI #1104 FRONT PANEL CARD; REQUIRES A MAXIMUM OF 1.5 AMPS AT +5 VOLTS AND 100 MILLIAMPERES OF -9 VOLTS.
EACH “PAGE” OF MEMORY IN THE SYSTEM (256 WORDS) REQUIRES 200 MILLIAMPERES OF +5 VOLTS AND -9 VOLTS.
I use 5 or 6 AMP 5 volt supply for both SCELBI 8H and 8B.
regards,
Mike Willegal
regards,
Mike Willegal
