Stone
10k Member
Don't forgetFrom my reading, it sounds like we are dealing with only a couple major size barriers for machines made
in the 1990s and early 2000s. There is the 528MB limit, the 8.4GB limit, the 137GB limit and the 2TB limit.
The 4,096 Cylinder (1.97 GiB / 2.11 GB) Barrier,
The 6,322 Cylinder (3.04 GiB / 3.26 GB) Barrier,
The Phoenix BIOS 4.03 / 4.04 Bug (3.05 GiB / 3.28 GB) Barrier,
The 8,192 Cylinder (3.94 GiB / 4.22 GB) Barrier,
The 240 Head Int 13 Interface (7.38 GiB / 7.93 GB) Barrier,
The Windows 95 and the 29.8 GiB / 32.0 GB Barrier,
The 65,536 Cylinder (31.5 GiB / 33.8 GB) Barrier,
The Windows 98/98SE 64GB Barrier,
and
The FAT 32 Limitation (124.55 GiB / 127.53)
as they're all in this equation as well.
This is related to the way a BIOS does it's geometry translation. There are *other* limitations involved here and they require higher math. It is a rather complicated issue and takes a while to digest properly, at least it does for me.I tried installing the 120GB into a P90. When I tried to do an AUTO-IDE detect, the BIOS hung. I did
not try setting the parameters manually to some lower value (like using TYPE 1) so the machine could get
past the POST and I could install EZ-BIOS to see what would happen. That will be tested later. It did
AUTO-DETECT a 20GB drive.
I tried installing, one at a time, the 20GB and 120GB drives onto a P233 MMX which has LBA capability. The BIOS does AUTO-DETECT both but it does so with the same parameters as an 8.4GB drive: 16383 CYLS, 16
Heads and 63 Sectors. It shows the total capacility as 8.4GB for both drives (the same as the native
8.4GB drive which is already in the machine). The 8.4GB capacity is real as I tried to use FDISK from
Win98 to partition the drive and could only partition 8.4GB.
Interestingly, the above parameters are listed on the lable for both the 8.4GB and 20GB drive. How can
this be? There are no parameters listed on the 120GB drive label.
I ran a couple freeware utilities which show the P233 has extended 13h support. Yet it seems limited to
8.4GB.
