Hey question gang.. I am horrible at math and calculating the sectors, and cylinders, etc. So I formatted as a Priam V185 drive that I once had and I have the specs. Sure enough works perfectly like a charm. Its around 80mb and it represents the correct blocks and fsck's fine. But since this is a 190mb Maxtor is there any way I could bump up the cylinders and maybe heads to squeeze out what I can. I do believe the limiting factor here is the max heads. So the specs for a Priam V185 are: Max Cyl - 1166, Max Head - 7, Max Sectors - 16, Sector Size - 512, Trak Skew - 1, Sector Interleave - 0, and the make is listed as a Priam and size is set as 80mb.
So I am not sure if there is a ceiling of 80mb on this machine or if it has something to do with the max heads. The Maxtor is around I think 15 heads as I mentioned before and it does not like that... So if I were to bump it up to 8 heads, and bump up the sectors and max cyl. what size can someone recommend I try? And I would need to know each of those values to give it a try. And what the amount of space I would be able to try out (I realize that the setting for size probably doesn't really do anything and the model type). Any help would be really appreciated...
I have a hard drive bible V8, I might take a peek through that and see if I can see a drive where I could bump it up and get the max amount of space possible.
