Arcadetech04
- Joined
- Nov 14, 2023
- Messages
- 32
I thought the photos were fine, when viewed full size.Wow, terrible photos.
I’ll try this one.
If I can find a PTR card or a schematic, I can definitely wire wrap a circuit. Shouldn’t be that hard. After all, all you really need is an eprom, 4 74ls93 and a sequencer. Then all you need is a ribbon cable connecting to the interface.The TI steel-pin rust curse strikes! An EPROM-based PTR replacement would be quite nice. Fit it into an empty double-wide slot in the rear?
A few tubes of 7440 and a couple of tubes of 7474 would be a fine idea.However most things that blow up are the NAND gates (they're used as drivers and thus take a lot of load) and the flip flops.
You may want to confirm that the 74LS family is acceptable for replacing all of the dead 74 family chips you find. My recollection is that there are some cases where only a plain 7474, for instance, will work. Factors include switching speed and the actual internal circuit of the flip-flop, in the case of the 7474. On other flip-flops, the outputs are buffered, but I think there's one case where DEC drives the outputs of a 7474 directly since the output on that is not buffered. Vince can probably recall where I'm remembering this from.
The Posibus is not a trivial bus to interface to, but it's of course quite possible. I recommend studying any of the I/O devices from DEC in order to learn more about the bus. If you're not looking to do any data break (aka direct memory access), it's much easier.
Hmm…
Thanks for the info. I would think that a buffered output would add a bit of reliability to prevent feedback triggering of the flip flops.
Maybe I’m wrong??
Careful with LS versus standard 74xxx parts as LS parts have substantially less fan-out when driving standard 74xxx.Yep, ordered 100 SN74LS00, 50 SN74LS74 and 50 SN74LS40
Next question….
Does anyone out there know how to access any form of a buss or maybe I/O buss for an 8/L ?
Like add something more than a Teletype or a Paper Tape Reader.
Something like a Chuck E Cheese Robot or Dot Matrix Sign. That would be fun.
The Posibus is there, and is easy enough to interface to. Mainly it's physically cumbersome, conventionally with 3 double sided paddle cables for bus in, and 3 more for bus out, and that's for the simple non-dma case. There's a memory 'bus' too, but you'd have to build the mmu to go with it.Does anyone out there know how to access any form of a buss or maybe I/O buss for an 8/L ?
Well, I ended up with replacing about 1/3 of all IC's in the machine. And not only the IC's where a problem, I had to replace quite some transistors since the legs rusted of. Espescially the TO-5's that where mounted with a plasic spacer between the board and the package.Well this sucks.
As I was checking the M series flip chips, I notice rust and green corrosion on quite a few of the ICs leads. So much so, that my meter shows low or shorted leads.
So now, I am pulling every flip chip and the ones that have any corrosion will rebuilt from the ground up.
Anyone know just how many DM/SN7400 ICs are in a pdp-8/L?
Damm near 100 ICs.
Yea, some learning curve. But, I’ll fix each and every board. Just need some time.
I’m also now looking for a paper tape reader.
Or, if I can’t locate one, I’ll build an eprom version using some 2764 eprom in an old game cartridge.
Store all my programs on EPROMs.
That explains a lot. Tested ok outside the 8/L but not in the the 8/l. Kept thinking the fault was elsewhere. Thanks.Careful with LS versus standard 74xxx parts as LS parts have substantially less fan-out when driving standard 74xxx.
