memory testing software
wolfie
ontario
what is the best memory testing software out there? i have tons of memory and i plan on testing some time and i need a software that will do a thorough job. what do you guys recommend? i plan on doing all this testing on one of my many 486's.
i forgot to mention that i plan on using floppies. i am using motherboards and floppy drives pretty much. no hard drives no cd drives. another question. is there a software that tells you the speed of your memory?
memtest86 should fit on a floppy and should give you some information about the memory chips at least with more modern memory.
Edit: They have a floppy ready for you in the download section in the link I posted.
Hi
In general, the March C or March C+ are good test
and generally what is used by the manufactures.
Still any good suite should include a retention test,
read disturb test ( for static RAM ) and some type
of adjacent cell test ( but that requires some knowledge
of how the RAM was layed out ).
I don't like the address generation used for most of these
test. I prefer what I call a un-graycode count. It
insures the most bits changing on each address increment
so that it give the address decoder a good workout.
Dwight
i have test all my 1MB chips with memtest86 and they all tested good. now all i have left is all my edo memory to test. i think i might be testing for a whille lol.
