As others have said above it depends on what the MFM controller is installed in, and how easy it is to replace. So I have a number of beasts such as VAX 1000 and IBM terminal controllers which need MFM drives and replacing the controller is hard, then an MFM controller is a good, but perhaps expensive solution. I have one of these...
https://www.pdp8.net/mfm/mfm.shtml
... but in many cases replacing the controller with IDE or SCSI controller and then adding a SCSI22SD or IDE to CF card adaptor would be cheaper.....
